moomaloo
The metal dust cap from one of my Rega RS3s has worked its way loose (and actually pulls off). How do I glue it back on..?! Any particular glue? Anything to watch out for?
It’s a little odd because both the cap and whatever is behind it appear to be totally clean. No glue residue and nothing to suggest how it was fixed in the first place.
I’ve checked the cone as best I can and there’s nothing to indicate any damage there.
Thanks.
Thanks.
