I have a Rega Planar 6 turntable, Ania Pro MC cartridge, and Aria Mk3 phono preamp. The Aria suffers from a buzz or hum (60Hz or 120Hz) noise that's noticeable at normal volumes when not playing a record, and after extensive troubleshooting the most likely culprit is noise in my AC mains and seemingly poor filtering in the Aria.
How I arrived at this conclusion is if I listen to it with a battery powered amp & headphones, with nothing else connected (ie. no turntable), regardless of where in my house or how I spatially move the Aria, the noise remains the same. Some other notes:
- The noise only occurs on the MC settings, not MM.
- The Aria uses a 2-conductor polarized plug, and grounding the chassis to the outlet makes no difference, which rules grounding issues out.
- It is very well shielded, with a solid aluminum chassis, and all pieces grounded, and also the noise is consistent regardless of location or orientation, which rules out any RF interference.
- I’ve since tried other preamps (Rega Fono MC Mk4 and iFi Zen Phono) which are dead quiet.
- I tried a Furman line conditioner to no avail.
- I'm out of ideas :-(
I've seen many online reports of hum issues with the Aria, so I'm wondering if anyone has found a way to fix it? I otherwise love the sound of it, but the hum is forcing me to look for alternate solutions.
I heard @paul darwin from Rega participates in this forum, so I thought I'd give it a try to see if he might have any ideas.
