I use L'art du Son. It's big advantage over alcahol, is that the record stays wet for long enough for the fluid to do it's work and you end up with a clean and static free disc.
I don't mean that they are one and the same, but that I'm unaware of any surfactant that doesn't have at least some detergent activity and vice versa. Within a low tech activity like cleaning a record surfactant activity and detergency will both have a function and a component can wear both hats. Unless I have this wrong?Not actually true, but to avoid boring everyone, I will direct anyone interested, to Wikipedia.
I use L'art du Son. It's big advantage over alcohol, is that the record stays wet for long enough for the fluid to do its work and you end up with a clean and static free disc.
...IPA mix evaporates quickly after vacuuming, leaving the record ready for the sleeve that much quicker
I leave the record out on a little strand
...I'm amazed that a strand can support the record. . !
Have had a few bottles L'Art Du Sol can confirm its does mould.Apologies - I should have checked rather than rely on memory.
That said, the mention that I have seen of the enzymes in L'Art Du Son have referred to mould growth.
@foxw, I'ts probably the washing up liquid that's causing the gunk on stylus.
I doubt that there is any salt in modern washing-up liquid - it would have to be added as it wouldn't be a by-product of the anionic and non-ionic surfactants used today.
In the past, perhaps they added washing soda, to reduce/eliminate scum formation???? Today they just add tiny amount of chelating agents, if anything, plus disinfectants.
OK curiosity got the better of me and I googled it... My memory works fine.. (this time anyway!), yes it's loaded with salt.
Just Fairy Liquid here and it is not on the ingredients list. Salt also interferes with srufactant action - which is why you need special soap to wash in sea water.
I shall evaporate some down now - what sort of quantity is supposed to be in it?
