Hi guys, some of you may recall that I had network issues with my current Samsung mono laser printer which have never really been resolved so when I want to print now I have to go to the printer and connect a USB cable from the printer to one of my laptops which are a MacBook Pro (2015) and an HP laptop running windows 10.
Anyway the printer requires a new print cartridge so I’ve decided to buy a new printer now and one with a network connection ie a cable to connect direct to the Drayton router as they’re next to each other I’m not too fussed about a usb connection but maybe wireless and maybe AirPrint.
I don’t print a lot maybe about 300 or so A4 invoices a year and I rarely use the scanner in the current MF printer but I do use it occasionally.
The cost of printed pages isn’t really an issue or the cartridges either but not extortionate either but what is most important is for the bloody thing to connect to my router & network and basically work out of the box more or less within about ten minutes and be stable with no more faffing about with a laptop on one hand and trying to connect a cable to said laptop with the other.
I’ve had a look at the new HP laser printers that you can refill with a syringe for about £15 but the reviews regarding connection to network and setting up when new has put me off those same with brother printers and xerox printers too which all seem to suffer from network issues although I do accept that not all of those network problems are down to the printers and or their software and hardware.
Budget is about £200 including vat and delivery.
Tony
Tony
