John_73
Hi folks.
Having issues getting a 5mm ultra bright orange LED to work properly in a Quad 303. The neon lamp is pretty much kaput, and doing some Googling around it seems most recommend placing with an LED coming straight off the psu cap. Dada offer this in their kits too.
The measured DC voltage right off the caps is 78V. Forward voltage of the LED is approx. 2.2V. Forward current is 20mA.
Using ohms law I end up needing approximately a 3.7k current limiting resistor, at 1.5W. I used a 3.3k 2W metal oxide PR02 type I had to hand.
The bulb lights up perfectly fine, but the current limiting resistor gets hot extremely quickly, to the point you can smell the paint starting to burn. I’m sure if I’d left it it would have started smoking.
Have checked all wiring and all’s fine, and the amp was, and still is, working beautifully.
Do I need a higher wattage resistor, or use a different (non ultra bright) led type? I notice Dada use a standard red led, with a 12k resistor, and only use a 0.5W type. So not sure why I’m getting this over-heated resistor yet it’s specced for 2W?
Cheers,
John.
Cheers,
John.
