Thanks Tony, I thought as much. I collected a pair of Tannoys today and the seller(electronics engineer) had an Aladdin's cave of gear including 4 sets of 22/11's, all looked absolutely mint but I'm green where valve gear is concerned.The expensive valves are the KT66s, and they won’t be Mullards. GEC are what you are looking for there.
Hard to give a price range without more detail really, a lot depends on exactly what servicing has been done (some adds value, much subtracts).
I'll see if I can get more extensive info from him re the work he's done on them all.Sounds really interesting! Always fancied a set I have to admit.
The 22's aren't worth much - maybe £200 tops if in perfect nick, working, with original packaging. But the general consensus is that, unless you really want to stick with a full-period system, many modern pre amps will out perform them, are better suited to modern higher gain line level sources and will work fine with the II's.
II's are worth around £1300 a pair tops if working, in absolutely immaculate condition, with original packaging, a full set of original valves and a period correct electrical refurb. A good working pair without any original packaging seem to be anything between £800-£1100.
Untested is the main thing here - are they tested as working?
Ask him how much he wants. I'd open with an offer of £250 each if untested and £350 each if tested and go from there. You could probably make money on the 22's if you got them for £50 each, but I wouldn't go any higher than that unless I really wanted to use them.
The
I have 2x 22's and 3x II's, untested but in good nick and have been researching what to do with them.
Ask him how much he wants..
I think that you may have to revise your pricing on the 22 control unit, foxwelljsly. Once unloved , even non-working examples in decent cosmetic condition can make surprisingly high prices e.g.
http://rover.ebay.com/rover/1/710-5...0001&campid=5338728743&icep_item=133547832847
Earlier in the year a near mint example c/w original box topped £500
That seems to be a bit of an outlier. I was looking to sell mine, which are quite nice, and figured I could assume £120 each (untested) max. Also just noticed I have an FM1 in the box!
There is life in those Quad 22 pre-amps.
This is one of my latest rebuilds to be used stand alone with its own psu.
/\ A labour of love for the enthusiast really.... I would charge over £1K and I rather doubt anyone loves the 22 that much!
OooThere is life in those Quad 22 pre-amps.
