If it‘s DC coupled you‘d normally expect trimmers to remove the offset?
Or servo?
What I wrote here is bullsh@t, isn't it? The amount of DC offset from the DAC that makes it through to the speakers will depend on the position of my amp's volume control.The DC offset at the amp's speaker terminals when the DAC is engaged is 140mV on the Lch and 90mV on the Rch, so fortunately the amp appears to be blocking just over 90% of the DAC's DC.
I tested this on my 'bench-testing amp', a cheap Cambridge Audio A1 integrated, and my main listening Yamaha A-S3000 integrated.If you have a pre amp then its likely to have capacitor coupling.
Most power amps have unity gain at DC so even if there is no input cap it doesn't amplify DC, just passes it on as it were.
In passive speakers generally only the bass unit will see DC.
