bencat
Amplifier Destroyer par excellence
Right I listen to music via a server with a large hard drive with FLAC rips on . I have found that isolating the router and server has a positive effect on sound quality . Firstly I did this using a Cisco switch . Then I found using optical coverters to an SFP capable switch was even better . Recently I found out about DAC sfp cables which make the connection using copper wire . Tried a cheap set of this cable and this sounds even better than optical cable . You also get the advantage that being copper shorter lengths are better so tidied up the wire nest and the sound . Cheap generic ones are an improvement but for best sound I would suggest Amphenol sfp+ DAC cable more expensive but the best sounding this used SKEWCLEAR 2 wire which seems to make a difference .
