kristoffer
Danish Hi Fi NERD
Cheaper Sugar Cube alternative from Project?
Most of my vinyl are new , but this might still be a valuable device.
“Pro-Ject has introduced a new device that is going to be a must-have component for any record lover's setup. The Vinyl NRS Box S4 has quite a lot going on behind that minimalist exterior. The device can clean up any clicks and noise from old and damaged records to bring the record's sound back to the way it was intended. Designed to work between an amplifier and a phono pre-amp, the system can reduce noise by up to 8dB and has a dedicated knob to adjust its sensitivity.
Pro-Ject's Vinyl NRS Box S3 is the cure for damaged records
https://www.acquiremag.com/tech/pro-ject-vinyl-nrs-box-s3
