Power strip with 12v trigger..
Rug Doc
Does such a thing exist? Would make my life so much easier! I have used a remote (IR) one, but it takes too long to reset, so turning it on/off to quickly makes it use its place..
I could go that way again with a more reliable IR device.. but a 12v trigger would be ideal!
Cheers and TIA!
Bump.
If I can’t find one available, I might make one myself.. does anyone have any 12v 240v relays or a link to one that can carry a good amperage?
How much current do you need? I've got some nice gigavacs that would switch your house, possibly street (they are good for 800v 2000A from memory). Got some smaller stuff too.
Think I have some 5A solid state relays you can trigger off about 5-30v they are about matchbox size. I'll drop a couple over next week one evening.
EDIT: with your Bostons!!!
