Darth Vader
From the Dark Side
Do you have any idea what dynamic demands an audio product make on the mains supply?
If you did you wouldn't be making the inference that its is directly related to the audio signal.
Here is the dynamic mains current draw of a Marantz AV amp running 5 channels at moderate volume.
It shows the reservoir caps charging. It does not show the audio signal. 1mV = 10 mA. Made this measurement a few weeks back with scope and current clamp on the mains live wire.
Something for you to ponder. Where does the power come from when the AC cycle is at zero volts?
Bit of a hint there. My own amps have a single 7A quick blow mains fuse that feeds two 1.2KVA xformers but (according to Meridian) the amp can deliver a burst of 150A into a 1 Ohm load. Umm that 22.5KW so from where on Earth does all that power come? Magic or science?
Cheers,
DV
