Lee T
Care to share.Ah, in that case the answer is "yes, several".
In your opinion of course.This is the point though, the amps you refer to as "improved" by certain mains cables are hindered by the fact that they are sensitive (in a negative way) to subtle mains condition variations.
The penny may drop at some point
I have built amps, but it couldn't be less relevant.
This is so straw man it beggars belief.
The point in question was some claim that the amplifiers they use, or have used, are sensitive to subtle changes in mains conditions. Using certain mains leads allegedly improved this.
I was just highlighting that a shit amp cannot, ime, be fixed with fancy cables with no sound engineering basis.
Why would a loose pin alloy a better connection in a plug, surely all slightly misaligned would give greater contact pressure?
More contact area = greater pleasure
Now come on! You should know by now they HATE success on here!Endless upgrade path? No, there is a limit.
Another poster going on and on against Naim. They're still in business, which is better than many companies. Better? Maybe, but probably just different. Plenty of people on this forum have tried 'better' only to return. A bit like emigrating to Oz. Some prefer, some hate it, neither choice is wrong, right or better.
What is THE most expensive 'hifi' mains lead? I bet it's orders of magnitude more expensive than anything from Naim.
Care to share.
Foruma nervosa in all it's gloryMore than happy to - but can you first give your definition of "design"?
A lot of audiophile "designers" simply take a circuit from a manufacturers application note, or use ready-made modules, and the actual "design" part is coming up with an interesting-looking enclosure and some exotic but irrelevant auxiliary components for proper cred. Does that qualify too?
It's a Eureka momentNow come on! You should know by now they HATE success on here!
Ok, so same cable can be made for a tenner right, the seller sells it for £500, which cable is a rip offHow many have you dropped ?
Rhodium plated IEC plug £ 1.86 you would be a phool not to market these,
foil and braid 2.5mm 3 core mains cable £ 1.20 /Metre.
http://rover.ebay.com/rover/1/710-5...0001&campid=5338728743&icep_item=272556699603
£ 40/500 per Metre cable to you sir.
Oops forgot the snakeskin effect outer braid £ 0.60/M
Make a difference ?
Of couse it does with that kind of mark up.
Ok, so same cable can be made for a tenner, right, the seller sells it for £500, which cable is the rip off?How many have you dropped ?
Make a difference ?
A Naim Nait 5si sells for £500 then buyer sells to someone else for £3,000, which is the shit amp.
You have it all upside down & back to front as many others do here.
What are your thoughts on regenerators, surely these too are a waste of cash as any well designed amp should be able to cope with fluctuations in the power supply. I read a great post a little earlier from whatsnext, it's an absolute gem.
FWIW I see no virtue in poor design.
