I'm in the process of planning some tannoy cabinets for 15 inch golds, and rather than recreating an existing design, i'm doing something a little different. It'll be in the 120 litre or so size, so no bass monster, but it'll be a ported cabinet, and i'm wondering about the pros and cons of where you locate the port.
The planned cabinets will be on castors - this is a decision based on how we use speakers at home, and it'll make it much easier to position and move them around, and this then gives an interesting option, to put downward firing ports. Due to my limited woodworking skills, this would make it much easier to get a decent fit and finish on the ports, since they won't be visible.
So, if I were to port the speakers on the bottom, what would the effect be? Should I consider the path length from the port to the edge of the cabinet when choosing the port length, or will it be irrelevant? I'm thinking that various subs do this successfully, but it's not clear to me if it affects the design.
Any insights welcome!
