a.palfreyman
Some 'styrene caps are end-marked for outer foil, but some don't appear to be. I've had a play with some unmarked ones by placing the oscilloscope across the end wires but after swapping the connections they seem to be similar in how much mains noise that is picked up.
Is it possible to determine which end is outer foil if they are not marked, or do these not have a full wrap of one foil and so are equally susceptible to noise?
