glenn jarrett
looking to power my pi4 from the original power supply as i have measured how much current my pi draws from boot up to running with usb pen drive draws 1.2 A max once settled after boot about 1.1A.
i know its pointless giving the pi a clean supply
but could i use the pi supply to give my tone board a clean supply by using TPS7A4700 regulator i know the regulator will need 7v or so volts to drop back down to 5v so could i use a step up buck set at 5v in 7v out then through the reg board to the tone board ?
or would this be a waste of time
http://rover.ebay.com/rover/1/710-5...0001&campid=5338728743&icep_item=174288170852
http://rover.ebay.com/rover/1/710-5...0001&campid=5338728743&icep_item=401742996970
20200522_153338 by glenn jarrett, on Flickr
CamScanner 05-22-2020 22.06.23_1 by glenn jarrett, on Flickr
