Following a Laptop Win 10 and SSD upgrade I'm unable to open my Nikon D810 files because I forgot to backup the Raw update file
The D810 needs 8.7 on and CS6 only supports upto 9.1. but Adobe now only does the standalone DNG converter which takes around 1 minute per NEF file and I need the Camera 8bi file so I can do the conversion within Photoshop
Can anyone help? - It should be in your c:/programfiles/commonfiles/adobe/plug-ins/CS6/file formats folder. My CS6 installs version 7 dated 09/02/2012
