flippin eck!
there's a lot of phono stages out there, valve, solid state, Brit, American, German, Danish.
What are the logical steps to take when considering which one to choose?
I understand that many Garrard 401 owners go for valve phono stages but should one base it on the choice of cartridge or the combination of deck, arm, cart?
low output mc or high output mc seems to be one way of differentiating but if buying 2nd hand and maybe from afar with no opportunity to dem then it is relying on others experience and opinions together with the intuitive approach relied upon by many a second hand punter, ah the thrill of the chase.
I'd like to spend as little as possible but have found so far:-
Rotel RQ 970 BX phono pre amp 80
Musical Fidelity X-LPS phono stage 99
moth mm/mc with separate psu 150
Michell ISO Phono Stage 250
McCormack Phono Stage New and Boxed 399
Lehmann Audio Black Cube SE new & boxed 449
Cary 301 Two box valve phono stage,for MM or MC. £700
Can anyone help me focus a bit, i'm creating two options based on Garrard 401, one with OL Silver 250 arm and probable Ort. Kontrapunkt B and the other with RB300 and probable Dynavector 10x4ii.
Anyone know whereabouts of any Crofts?
Reason for my sudden surge of interest in a seperate phono stage is the imminence of my A'dale Grad 1 pre amp which i'll use with 135's initially.
Money is an issue but i've got kit to sell to cover any overspend of my original budget of 400 for something 2nd hand and I have decided that sound result is king.
Probably have to be quick too as my choices may diminish as stuff is sold.
Appreciate any feedback, Steve
