a.palfreyman
Guys,
I have a CD160 that I used for the first time in many years (was stored in the loft, boxed up. Also, the display doesn't work so can't read any messages etc.) It seemed to work ok and played a few discs part-way through, but last week, I ran it through a full disc and it began to "skip back" i.e. replay the same few seconds of music. I opened it up and noted some very slight deposit on the laser lens so took the transport out and cleaned this off using IPA and tissue. On putting it back together it will not now play a disc. When you load it it will either spin up and stop, or spin up and then stop and then spin the opposite direction before stopping. Anyone know what this could be caused by? I also noted whilst I had the transport out that the tracking arm is "free" to swing. Is this typical of this mechanism? I would like to sort it as I just bought a NOS re-clocker (this one: http://rover.ebay.com/rover/1/710-5...0001&campid=5338728743&icep_item=201927999150) to try.
TIA,
AP
TIA,
AP
