deebster
Half Man Half Biscuit
First off, apologies for rambling or if I descend into a rant as I'm fast running out of patience with getting the audio output on my pi consistently working.
It's a pi 4, 4GB, running LMS on piCoreplayer with USB output. I do like to use a monitor to control it from time to time so have Jivelite installed, and I also shut it down each night along with power to the ethernet switch box it gets its network feed from. I do this via the monitor as that is the only method of control out of the half a dozen I have that has a shut down option.
The issue is some days when I turn it on I get no audio output. From looking on its attached monitor or via LMS it appears tracks are playing (streamed from Tidal/radio or local ALAC files) but as I say, no sound. I'm sure it's not a DAC or amp issue as they both behave perfectly normally all the time except when the pi doesn't. It is only some days though, and often but not always a reboot is all that's needed. It will then play perfectly well all day and often for days, but then the same problem resurfaces. I do make sure the ethernet switch is on for a minute or so before turning the pi on, and I know the ethernet switch works as I also connect my work laptop to it.
I started on v6 of the pCP software and last week updated to v7 only to then read about issues playing ALAC files, but as recommended a full update to squeezelite seemed to fix the issue. Until the next restart that is, with you guessed it, no sound. After getting fed up with v7 and seeing no improvements to it I went back to v6.1.0 (full reflash of SD card and setup from scratch) and after getting the prompt to update it am now on LMS 8.1.1.
Yesterday it played fine all day, but this morning no sound. Then when I turned its monitor on (often it is off) I started getting sound through the monitor's speakers only. After removing/reinstalling jivelite and resaving the audio setting (which always shows USB) still no sound. If I turn HDMI power off I lose monitor sound and connection, but still get nothing through USB. When after a net search I end up on the forums where the developers hang out I quickly get lost on the issues and settings changes that are being mentioned.
It's such a shame as I really like what the pi and its software developers are doing, but constantly having to deal with issues is putting me off a bit. So, hand waved, sad face on, anyone able to help me out here please?
