Paint stripper v hot air gun
Discussion in 'off topic' started by Tigerjones, Jul 29, 2020.
  1. kensalriser
    kensalriser pfm Member
    Having a job you really don't want to do is a great way of getting loads of little jobs done. Self-help/pop psychology theory posits you should always do the biggest job first, but for anyone of sound mind the clear and obvious reward for doing the big job is a pass on all the others.
  2. Suffolk Tony
    Suffolk Tony Aim low, achieve your goals, avoid disappointment.
    Chemicals for the fiddly little crannies, but a good old-fashioned paraffin blowlamp for the bulk. Needs a bit of practice to avoid burning stuff to a cinder, but there's much pleasure to be had in priming the blowlamp up with meths (Ah! The Smell!), pumping it up, then getting a roaring flame going. Old paint doesn't stand a chance.
    Mullardman likes this.
  3. gintonic
    mainly hot air gun for larger surfaces. Decent shave hooks for the shape of surface you are stripping. I have two triangular ones, on with flat edges for flat surfaces and another with various different curved surfaces for more intricate surfaces.
    Keep the blades of the shave hook clean.
    I just did a door frame with a heat gun and spoke shaves - managed to get in all the intricate mouldings, which were all parallel.
    on a more complex object like a ceiling rose, I'd get straight for a chemical stripper
  4. Big Tabs
    Big Tabs pants up, knee down
    We had all the 7 internal doors 'dipped' by a company (in acid I guess)
    They came up looking amazing, then I treated them with clear neutral danish wood oil.
    (the doors are approx 120 years old.)
    Tigerjones and Suffolk Tony like this.
  5. gintonic
    some doors are worth doing that way. Others are not. My brother had what he thought were 4 >100 year old doors stripped, only to discover they weren't that old, and the stripping process ruined all the doors.
  6. Suffolk Tony
    Yes, I had this done too, and you're right, our door looked terrific also - every scrap of paint and crud removed. When you do it yourself, getting the last little flakes out of moulding's a real pain.
    Big Tabs likes this.
  7. chartz
    chartz pfm Member
    Definitely stripper. I tried the hot air gun, and it damages what's under the paint. Useless.
  8. Tigerjones
    Tigerjones Bagpuss
    I think Danish oil is a great way to finish wood.
  9. gintonic
    didn't damage anything on the door frames i recently stripped. Only time i have scorched then underlying wood is through my mistakes. You need to be gentle and keep the gun moving at the perfect distance for what ever you are stripping. This takes practice and skill.
  10. dweezil
    dweezil pfm Member
    Took me a day to blow torch my first door so hired a decorator; he made such a charred mess of his first door that i terminated his employment.
    Later found out he burnt down a house across the valley when a bit of burning paint dropped through the floorboards and found some dust.
    Light sand and a fresh coat of paint worked well, varnished pine would have been out of fashion by now anyway.
  11. cooky1257
    cooky1257 pfm Member
    Yeah, these days I'd remove the skirting and get it dipped.
    cutting42 likes this.
  12. matt j
    matt j pfm Member
    Sod all the hassle, just put another coat on over the top.
    mandryka likes this.
  13. Tigerjones
    Tigerjones Bagpuss
    I’m am kind of hoping I can leave it as wood with a bit of effort. There are many coats of paint to get through.
  14. JensenHealey
    JensenHealey pfm Member
    Getting it stripped by a dipping outfit probably cheaper than buying enough stripper gel. Not to mention your own time/effort. While the door(s) are away you can be getting on with other aspects of the project. When they come back, a light sanding and a finish of your choice.
    I am recent convert to Danish Oil on some Oak wood frames of my older (1785!) windows. They look beautiful now.
  15. matt j
    matt j pfm Member
    I'd like to see PJ taking his staircase to the dipper's. Netflix series awaits.
    tiggers likes this.
  16. Rockmeister
    Rockmeister pfm Member
    remove words 1,5 and 6. Replace 5 and 6 with suitable rude description of fantasy figure.
    1 glass of wine too many already. :)
    Tigerjones likes this.
  17. Tigerjones
    Tigerjones Bagpuss
    Hahahaha.
    The staircase will not be going near a dipper. How do you even take a staircase anywhere?
  18. sean99
    sean99 pfm Member
    https://www.cdc.gov/mmwr/preview/mmwrhtml/mm5013a2.htm
    Chemical strippers can cause lead to migrate from paint into the wood. It’s not safe to sand chemically stripped wood,and it’s not safe to oil finish chemically stripped wood that was previously coated in lead paint if young children might ever come into contact with it. F$ck$ing lead paint is an environmental nightmare and it seems that the UK lags behind the US in recognizing this.
    The paint companies should have been forced to pay for remediation but they were too well connected politically.
  19. Mike Reed
    Mike Reed pfm Member
    Step by step?
    cooky1257, sean99 and tiggers like this.
  20. Tigerjones
    Tigerjones Bagpuss
    Haha. Excellent.
