Gervais Cote
Predator
Gents,
I just finished the install of an fm antenna and I am wandering if the in ground earthing is okay.
The set up is that I have a coaxial cable from the antenna connected to a junction/grounding block and then another coax cable to my Naim NAT01 tuner.
The junction block is bolted to a galvanized steel structure that was previously used for a large tv antenna so the grounding is actually done by the metal to steel contact between the junction block and the galvanized steel structure. This galvanized steel structure is 4 feet deep in the ground. The junction block has a green screw that’s designed to tighten a 10 gage copper cable to allow grounding with a copper pin in the ground.
So my question is : is my actual steel on steel grounding enough against thunder strikes or should I add a 10 gage copper wire and a 3 or 4 foot long copper pin in the ground ?
