-alan-
I have one of the budget micro-processor controlled/multi-programme chargers which can - in theory at least - vary the charging current to suit the current state of the battery.
I've been using it in 'trickle-charge' or what I think is supposed to pass for one on a small 12V bike battery using the motorbike/smaller capacity battery setting. It seems to bring the battery up to charge fairly well, and then hold it at 14.1V indefinitely.
- Problem is that if you leave it at that setting for a longer period of time, within a couple of weeks the electrolyte levels drop to the point where the plates are uncovered, which can't be good. Kind of defeats the object of a fit-and-forget tricks-charger if its boiling off the electrolyte methinks ?
D'ye think I have a faulty charger - or battery - or is the drop in electrolyte level just part and parcel of charging an old-style lead-acid battery ?
