Old hifi systems with great sounding drum kit cymbals
Discussion in 'audio' started by Guitarist 28, Jan 4, 2022.
  1. tuga
    tuga Legal Alien
    I said earlier that systems are agnostic. They deal with electric or digital audio signals. They can't distinguish the sound of a jet plane from that of a dog barking.
    Systems produce sound, they don't convey anything.
    Different systems may trigger different emotional responses when reproducing the same music, but it's still because of differences in frequency response and dynamics and detail, all measureable. Even your response is measurebale to a certain point with fMRI.
  2. Mr Pig
    Mr Pig ^'- -'^
    I fear high quality music reproduction may be wasted on you. Either that or you're just being obtuse.
  3. tuga
    tuga Legal Alien
    One nowadays very common example is a speaker measurement using REW.
    The software generates a digital audio signal (sweep) which is converted by the DAC, amplified and transduced by the speakers, then captured by a microphone and converted back into a digital audio signal which is then analysed across a wide array of parameters.
  4. chartz
    chartz If it’s broke fix it!
    No. I enjoy my hi-fi a lot more than my radio.
    tuga likes this.
  5. Mr Pig
    Mr Pig ^'- -'^
    Is this what you do at home?
  6. tuga
    tuga Legal Alien
    Actually it is you who prefers lower quality music reproduction, and you're being vulgar.
  7. tuga
    tuga Legal Alien
    I do it whenever I move my speakers in the room, move house or change speakers. I use the measurement to produce Parametric EQ filters which tame the room-induced peaks and make the frequency response at the listening spot resemble the audio signal a lot more.
    Unsurprisingly it sounds better too.
  8. Mr Pig
    Mr Pig ^'- -'^
    Actually, only you said that. You don't know anything about the quality of my system but chose to try and undermine my opinion with this insult.
  9. tuga
    tuga Legal Alien
    The mastering engineer receives a master tape. He gives it a listen and then makes a few tweaks. If he isn't using accurate equipment this can have catastrophic results.
    Imagine editing a photograph with photoshop using a colour TV set from the 80s vs a high accuracy flat display from 2021...
    The old CRT TV will be more forgiving and maybe take us on a trip down memory lane. To some people it may even convey a bit more passion.
  10. Old Shatterhand
    Old Shatterhand pfm Member
    @tuga As long as your room isn't the same or your devices aren't the same as the ones used from the recording engineer your solution with a DSP and your speakers are as much as far from the original sound as everyone else's system. If you think yours is more accurate you are fooling yourself IMO.
  11. Old Shatterhand
    And who defines accurate equipment? What is accurate? ME Geithain? Adam Audio? Genelec? Tannoy? Dynaudio? KS Digital? PSI? Event? Quested? Mackie? M-Audio? Neumann/Klein + Hummel? Do they all sound the same?
  12. tuga
    tuga Legal Alien
    Measurements define accuracy.
    But speakers are different because different topologies produce different results. I had mentioned that earlier in a reply to one of your posts:
  13. Old Shatterhand
    Measurements with microphones which alters the sound?;)
    There is only one reference and that is what happened before the recording aka live music, everything else is artificial and therefore has no reference for accuracy. A linear frequency plot is only a linear frequency plot. You can say monitor x is as linear as monitor z but that's it and is absolutely meaningless. No speaker sounds like the other.
  14. tuga
    tuga Legal Alien
    That is the logic of some ASR members.
    But it is flawed.
    For one because there is only an original sound when all instruments were playing together at the same time. That almost only happens with classical music.
    Then you need to capture that original sound with a single pair of mics. That hardly ever happens nowadays (maybe 0.1% of recordings are made that way).
    What is common is the stereo mix, a set of different captures which when combined results in the music.
    So the original sound is, in reality, the master tape. But that master tape is then mastered to a final recording, to be issued on vinyl, CD or a file. And what does it consist of if not the audio signal? Accuracy to the recorded signal.
    I would be fooling myself if I thought that there could be any other type of accuracy in audio.
  15. tuga
    tuga Legal Alien
    Alter the sound? In what way? Microphones and mic preamps can be calibrated, just like monitors, to ensure accuracy:
  16. Old Shatterhand
    I don't care for ASR.
    You confirmed it yourself with post #94. Accuracy is wishful thinking nothing more.
  17. Old Shatterhand
    Calibrated by an artificial reference.;)
  18. tuga
    tuga Legal Alien
    Accuracy to the original event is not posible, only accuracy to the recorded signal. That is what I have said.
  19. tuga
    tuga Legal Alien
    What's that supposed to mean?
  20. tuga
    tuga Legal Alien
    the caretaker likes this.
