darrylfunk
Banned
thanks very much for that richard.
have you checked out the heed amplifiers as i believe morgan/deva are no longer too?
What happened about this? I PM'd you but I bet your box was full pretty quickly!
Gromit,
I have an Ob 3/X-Pak and also a couple of pairs of Royds. Great combo. The Ob3/X-Pak is a fabulous amp. Don't forget it cost twice as much as a Naim Nait when it was new. FWIW, MS loved the Ion combo when he had it and he was/is a die-hard Naimophile.
Not sure what you're actually asking for NRWler 04 but heres the original spec for the 050 electronic crossover for the EXO/CXA
This is for the 050 with the ARC recessed dome tweeter (Stick on arc logo)
There were a very few with Scanspeak tweeters - VERY rare
Xover freq 3Khz
HF 1dB down on LF (LF pot at max - HF pot about a 10th backed off)
HF out of phase with LF (Set by little wire link on board
If anyones interested I have the circuit for the 2 way Crossover card
Also about to restore fully a pair of CPA 602s and will post info if theres interest
I had a linn lp12
ion obelisk 3x xpac amplifier
Royd Edens on linn kan stands
It all made quite a good noise
