Mike P
Trade: Pickwell Audio
Regulars of the classic section will probably be aware of the new belt which I've brought to the market for the Thorens TD124.
https://pinkfishmedia.net/forum/threads/thorens-td-124-ii-restoration-upgrade.111036/page-26
We've also done a belt to suit many Thorens belt drive decks such as the TD150/160/125 etc.
I've been using one of these on my own TD125mk2 for a while now and it really is superb, even if I do say so myself. It's deathly quiet, just perfect in length/tension and dropped the measured wow on my deck from 0.2% to 0.07%.
This belt has a diameter of 165mm, circumference of 518mm, 0.8mm thickness, 4mm width and is designed to suit decks with a belt path distance of 563mm (measurements taken from my own TD125), thus giving about 8% stretch.
The data I have suggests that this same belt will also fit a number of other classic belt drive Thorens models such as the TD126, TD127, TD160, TD166, TD145 but I haven't been able to verify the measurements myself.
If you're not sure if this belt is suitable for your deck please measure the belt path length. It would be very useful to have this information anyway, even if you're not interested in buying a belt from me!
TD125 belt 1 by Michael Pickwell, on Flickr
I've just received my first batch of these so drop me a PM if you're interested in buying one.
I've also got longer and shorter belts available too if anyone finds their deck measures up differently.
