mattgbell
Help the elderly and unwell!
They look great.
Don't they just!
They look great.
They are here, and they sound mighty impressive
I can’t believe how much I was missing until now.
More impressions will follow...
The right speaker is extremely close to the side wall and this should make its tonal balance quite different. Have you tried putting the tweeter & mid on the inside (swapping L & R speakers)?
Tuga, it’s not really visible from the picture, but that is a chimney and the front of the right speaker is almost flush with the chimney.I have some space after the chimney so it’s not the actual corner of the room.
At the moment I have adjusted the treble, low mid and low end on the Neumanns to compensate for this and to me it sound great.For now I am getting used to the change, and then I fire up the Umik1 to make final adjustments.
By ear, at the moment, this is the best sound that I ever heard in my room (and much more)
I can’t hear the subwoofers, but I damn miss them when I turn them off.
It was really worth the “risk” and thanks to everyone for the contributions
How are you getting on with the subs now you’ve had more time with them?
What is the basis for considering them to be higher quality speakers?For a long time I had the itch to go to ATC 50's or MEG 901, and although they are higher quality speakers,
