slapup
Your local friendly bobby
Following the advice on the McBride website
But it turns out that when you do make the effort of mounting the regs inside the preamp box, right next to the circuit, and whip out that 27 ohm resistor (so allowing a true low impedance power rail) then I find the preamp performance (particularly timing) suddenly blossoms. And this is why you should stick the reg circuits INSIDE the preamp box. If you decide to keep the regs in the psu box, then leave the 27 ohm resistor in.
i have moved the regs from inside my SNAPS to inside my 32.5. Being a total gimp however, can someone explain to me where the 27ohm resistor is? Do i need to replace it with a wire link?
