Hi folks,
Admittedly a relative newbie to tinkering with amps but am no stranger to a soldering iron.
After securing some used NCC200 boards from a fellow PFMer, I installed them in my NAP140.
Upon installation, the bias on each board was reading around 26 mv so was adjusted up to 36mv.
Al seemed to be working fine for a couple of hours initially as things warmed up, although upon initial listening I was somewhat underwhelmed, finding the performance very similar to the Nap140 in stock form.
After a couple of hours I switched the amp off by the front switch in order to swap speaker cables from the NACA5 I was using to my Atlas cables.
Switched the amp on and the glass fuse blew immediately.
Disconnected the amp from speakers and any input, replaced the fuse for a 2A slow blow fuse and tired powering up again. This time there was a pop before I quickly turned off the amp (fuse did not blow).
On removing the lid the LM317 voltage regulator has exploded and burnt some tracks on the power PCB.
So far I am at a loss. Was part of the power unit simply on its way out and coincidentally blew shortly after I changed to the Avondale boards?
I cannot help being suspicious that I have done something stupid to create a short even though the only change was to crimp 6mm spades in place of the 2mm ones.
Could increasing the bias with an admittedly cheap meter have caused such an issue?
Any input gratefully received!
