jusphish
Enthralled by Naim
Can anyone recommend a specific cable that works for system automation between a current Naim streamer such as the ND5 XS2 and Naim preamp such as NAC 282?
I have tried a couple of basic mono 3.5mm to mono RCA phono cables, of which one didn’t work and the other worked only once and a while, with the plug almost, but not fully, inserted on the streamer end.
In the past I was able to easily connect the same ND5 XS2 to a Supernait 2 (which requires a different cable), so still working on the assumption that this is a cable/plug fitting issue.
Looking for one that’s known to work, and would appreciate any leads.
