I’m curious as to what this ‘design flaw’ might be? Does it apply to all the regulated amps, 250/300/500?
What Mark describes as a design fault is perhaps a case of Naim never paying more than they needed to for components and consequently rather under specifying some components (i.e. a NAP180 I bought a year or so ago had a power supply voltage of 39.3 volts and the the reservoir capacitors were 40 volt rated, a bit close for comfort, especially if you have a high mains voltage).
The specific "flaw" on the 250/135 regulator boards is the marginal rating of the power supply regulator boards' 10 microfarad capacitors which could be uprated to higher voltage/higher temperature versions to advantage.
These capacitors are the ones that regularly fail on 10 years or so old 250/135s and is where the legend of Naim amps needing regular servicing comes from.
If you can do it yourself they're cheap as chips and the rest of the range probably don't need servicing for MUCH longer periods.
