Your terminology is correct but the pips are the locating pins... And I know that's what the picture shows - but it's only for the pins - trust me - I've been in touch with them & anyway £12 each is a ridiculous price
@gary1064 Turn's out that Tom Tom do have the washers separately - £3 each so I got a complete set. The guy I spoke to suggested replacing ~ 5 years
For reference, when they arrived I measured them with a micrometer - 9 thou in the middle - 12 thou where the little nodules are. I'm sure if you could get some 12 thou aluminium sheet & a couple of die stamps you could cut your own if they ever become unavailable
Naim sent me a free set of washers about 7 years ago. The last time I took the top box off to tighten up the drivers the washers did look a bit flat compared to when they were new. So I guess I’m right in saying the washers are £3 each? £12 for each PIPs seems a bit steep but you only need to replace them if you lose one or more down in the lower box.
