RichardH
Bodging pleb
Cheers Andy - some of your suggestions I had already decided to do - mainly the re-jigging of the layout and adding screened signal cable. The eventual plan is for this to go in "prefix position" - i.e. underneath the LP12, so this is all a temporary home for it while I play with the phono boards. Hence the wayward signal wiring.
I think the hum is being caused by the unregulated DC, as the boards have performed fine previously when fed with a regulated signal (though the new diycap confused matters). So I'll probably first rejig the layout of regs and 323s, having DC coming in from one side, and signal in and out from the other side.
Re the 0v from cartridge, I've been slightly naughty there - for expedience while fiddling, I have tied the LP12 earth strap back to the preamp 0v post (I see that Tim's doing the same) - as the hicaps that supplied both pre and phono power shared a common ground, I thought that would be OK. I did also tie the -ve on the BNC back to the 0v coming from the power supply - hard to see in the pic. One more thing to address now that the PSU isn't connected.
Looks like I have my weekend planned
If all that fails, I'll pop some regulatio in the PSU box itself.
