Ced and others,
There are several interactions going on here that need to be understood: -
The 27R provides several functions and they all interact in some way.
It raises the impedance of the power supply at frequencies where the capacitor following it is not of sufficiently low impedance - this is generally a bad thing.
BUT, the relevance of low impedance is related to two things, how constant the current demand of the preamp is and the number of circuits being powered and their interactions.
Intuitively the constant current sinks will work better at LF, so the higher impedance down there may not matter quite as much as first thought.
BUT again there's more
You also have to consider the effect of the local capacitors on the
regulators. In the case of super regs adding extra output capacitance degrades certain parameters, so there's a balancing act here between improving rail impedance by lowering the R (which does improve sound) and applying too much cap load directly to the regulator, worsening it's performance.
This then starts to determine the values used here, with an LM317 it's performance starts dropping off at a very low frequency (circa 100Hz). Augment this with an RC that's improving as frequency rises and furthermore prevents interactions between the different stages of the amp and things may work better this way.
With the super reg's things are different, it's performance is maintained to a higher frequency before it degrades and starts from better point anyway. In this case there is some advantage to
reducing the series R, whilst lowering the rail capacitance to form a higher rollof, reducing the sonic signature of the capacitor from the end result.
It even allows the rail cap to change to one of far higher quality, with great sonic reward.
From my own perspective, when using 1 reg / circuit I would dramarically reduce the series R and the C, but if powering more than 1 circuit / reg I would use a modified RC, determined for a specific application.
For those who don't already have this info, feel free to mail me and I will offer advice privately.
Re: Mark's P.S. I agree here, time is the great determinant to whether things are better, but I disagree more than ever about the flat / round thing. Often changes seem to improve both elements and you can have your round earth elements alongside your flat earth bits. Now we always want the FE as the primary elements, but when you add the two together, as opposed to the diametrically opposed camps that so often appear, it makes for an incredibly involving and engaging experience.
For example the ability to hear the acoustic around the recording, whether artificial or real, does not have to be some artificial element added to the music, but can be due to a very real increase in low-level resolution that brings to the fore previously hidden information.
This gives very real insights into the nature of the recording and the music, you get lots more details and clues about the music, the byproduct of which also manifests itself as what some would refer to as round earth stuff.
I don't listen to this and think 'air', 'space' or whatever, but think how much more
accurate and convincing things sound when these elements aren't to the exclusion of the underlying musical elements of pace, rythm and timing.
Andy.
