Long-winded post that probably has a simple answer especially from those with experience of the Naim streamers used with Teddy psu’s. But, the more detail I add now the less people will spend wasting their time with ‘have you switched it on?’ Etc.
I own and use an NDX streamer with a Teddy XPS PSU and a Teddy burndy single cable with great results.
However, the bug bit and I’ve bought a used NDS from a (really decent) PFM member. Actually, the NDX and TP XPS came from members here too.
Issue - the TP xpS + TP burndy work brilliantly with the NDX.
The NDS came without a PSU. However, I was under the impression that the same XPS + burndy would work with the NDS (with the plug in socket 2 on the rear of the NDS).
The problem is that the NDS starts up, functions correctly, finds network and will output a digital signal.
It will NOT output an analogue signal. I’m using non- Naim amps so use RCA phone’s.
I’ve tried every combination in the front panel config, phono disabled, enabled, din + phono and still no analogue output.
A clue to the issue may be that the green Naim logo is not lit either. But, I’ve gone down a rabbit hole of internet searches with some mentioning pressing the logo to get it out of mute but I was under the impression that function was for the early 272, SN, uniti etc.
Another presumption I’ve made is believing that the TP XPS + burndy will be directly compatible with the NDS. Have I got this wrong?
Any help, tips or even the correct answer greatly appreciated - I was so looking forward to getting the NDS up and running.
I’ve sent the Teddy Pardo website an email too with a request for help.
A post I made asking for help on the Naim forum lasted 15 minutes before being pulled - fair enough I suppose. It was a little cheeky…
