oh,okay. Any tips to how to check the bias on my unit, I checked and it the boards is NAPA6/3Those two legs of the resistors are joined together on the PCB hence no voltage. I would recommend you not altering anything unless you're 100% sure of what you are doing. Making a mistake on this could be costly.
Especially, don't use the current ranges on your meter when it is attached across any of those resistors.
I saw a lot of method, and that too, just measure across one emitter resistor instead of two, then determine if it needs more or less. But seing that you can also do the one on the right is also interesting. But what if I want to measure across two resistors? I’m guessing hook up to the one that is next to it?If you attach the black probe to the other end of the resistor it is currently attached to you will be measuring the voltage across one 0.22 ohm emitter resistor.
The post by #5 by @PaulMB here explains how:
https://pinkfishmedia.net/forum/threads/nap140-diy-servicing.123132/
Again, if it's working, leave well alone unless you're sure.
Thank you, so it is the most left and the most right. Front of the most left and the rear of the most right.The two emitter resistors are the one furthest right and the one furthest left of the four. If you want to measure across both then connect to the front of the rightmost and back of the leftmost.
EDIT: this is on the NAPA6/3 - others may be different.
Like this?No around the other way. It's front of the most right and rear of the most left.
Yea... but that will change next month. I’m swapping all back to tants. Did not know that the techs will swap it to lytics last year.A NAPA board with lytics instead of tants...?
