I have just disconnected the two pairs of + and - voltage 2.8mm connectors from the circuit boards, so that if there was a fault in the power section, it wouldn't blow the boards or the output devices. Everything looks good when slowly powered up with a Variac. No nasty flashes, bangs or wallops! I didn't actually expect that anyway.
I am getting just under 80vdc between the red and black cable ends which are currently disconnected from the circuit boards. So it looks to me as if the rectifiers are still fine. They certainly were the last time I used the amplifier, but it's been quite a while. Anyway it's all looking good if that voltage is ok...
