Naim NAP160 help
Discussion in 'd.i.y.' started by AdeBlackpool, Feb 3, 2021.
  1. AdeBlackpool
    AdeBlackpool My favourite power amp - Alchemist Forseti SS
    Hi everyone.
    Hope you are all keeping well.
    I have been working on a NAIM NAP160 with 1 working channel. Initially I noticed that the neg. speaker post on the dead channel was broken and shorted to the chassis. Both BDY56 shorted along with one small diode, a few cooked resistors, a shorted A06 tranny, etc.
    My question is regarding some tant values and resistors.
    It has had previous work done. The 10uf tantalums were all 25v, so I fitted the usual 10uf 35v Kemets. C2 was 47uf and C3 was 10uf. I'm thinking someone saved some money on cheaper tants as the circuit diagram shows 68uf in these positions. Can anyone shed any light?
    I have not powered up the amp yet, so I'm planning to first unplug the new BDY56'S as they are on the rear panel, then set basic bias.
    Power supply reads 37.5 v and has been re capped.
  2. Gervais Cote
    Gervais Cote Predator
    I have a fully recapped 160 bolt down and I took some pictures before and after.
    I am too dummy to post some pictures here but if you send me a pm with an email address I can send you these.
    A tantalum capacitor usually fail short when they get out of life and this causes damage on surrounding components so a full review has to be performed when that happens.
    In my unit, I also replaced the large resistors near the output transistors as they were slightly brownish probably due to overheating so I would recommend replacing these upfront.
    I took care to install them with a gap of at least 1/4 inch from the board to allow air circulation around it to help getting rid of the heat.
    My favorites for this are the Mill resistors with close tolerance.
  3. Gervais Cote
  4. Gervais Cote
  5. Gervais Cote
  6. Gervais Cote
  7. AdeBlackpool
    Hi,
    Thanks for the pics. I can't figure how to upload pics. Anyway, your amp is in much better condition than the one I'm working on. So, you have 3 x 10uf tantalums, 1 at the input and 2 back to back in the protection circuit area at the output end. So what values do you have for the other 2? 47uf/68uf
  8. Gervais Cote
    They are 47 uf in my amp but I know that some 160 came with some 68 uf.
    Not 100% sure but I think the bolt down version like mine uses 47 uf and the sleeve/chrome bumper version of the 160 uses 68 uf but I never came across a sleeve one so I can’t confirm.
  9. Gervais Cote
    This is where I go to upload my pictures and then download the link to get it here :
    misterc6 likes this.
  10. wd40addict
    wd40addict pfm Member
    My CB160 has 100uf in the feedback position.
  11. AdeBlackpool
    Thanks. I have fitted 68uf 16v in both positions, so hopefully this will be ok and matches the circuit diagram.
    Best wishes.
  12. AdeBlackpool
    I just powered it up. I have a bias adjustment range of 2 to 4 mV on the pot with the BDY56's disconnected. Supply rails are 38.3v and 38.1v
  13. MJS
    MJS Technical Tinkerer
    There's no bias to set if the output devices aren't fitted ;). But set it to minimum before you put them back in and turn it on again.
    Gervais Cote likes this.
  14. AdeBlackpool
    Thanks for that MJS. Obviously not, but the fact that I get 2 to 4 without them connected is a good sign that the rebuilt pcb is good and is similar to the other channel pcb. That was my point.:D
  15. Re: a NAP160:
    Please can somebody confirm if a NAP160 indicator bulb is either a 24 or a 48volt 'slide' style incandescent bulb?
    Thank you.
  16. wd40addict
    It's 48v and runs from the main 39v power supply from the big caps.
  17. Brilliant, thank you! You don't happen to have an original schematic of a NAP160 do you? I can't locate one that seems genuine, anywhere. It's the power and power supply section, rather than the amp boards themselves that I am interested in. Thank you!
  18. wd40addict
    Do you have the bolt down or chrome bumper version? I don't have a diagram of either, but what information are you after?
  19. timH
    timH pfm Member
    Think you’ll probably find it’s the same as all other NAP circuits. Differences were in the power supply - bigger/more caps, regulator boards or not, mono or stereo. Have a look at the acoustica site http://www.acoustica.org.uk/
  20. MJS
    The NAP amplifier circuit is 99% the same between most of them. Input and SoA caps are all 10uF/35v Tantalums, the feedback is 47uF or 100uF (or two 47s in parallel), and there was a 47uF across the bias transistor. Early 160s used two separate transformer windings to create two positive rails, and these were placed in series to create a dual polarity supply. Later ones were probably converted to use bridge rectifiers and wired conventionally.
