wylton
Naim and Mana member
I bought a rather nice, albeit cosmetically challenged NAC 32.5 last week. It coincided with the RSL boards I had on loan. The preamp sounded really good, but I needed to do something about the fascia; it was badly off colour and was very fragile. The previous owner had damaged the fascia when sliding the case off. I bought a replacement fascia from Lok Hi-Fi; quite expensive, but when needs must.
First, the volume and switch knobs have to come off & the two nuts on the toggle switches, then it's a matter of getting the old fascia off; I used a long-bladed knife.
I used some solvent to remove the old glue. Be careful not to get it everywhere; I used some cotton buds.
I inverted the chassis & put it on a sheet of glass to ensure correct alignment (the backing of the new fascia just peels off & sticks straight on).
Job done! I'm quite pleased with the result, just waiting for the new RSL boards to arrive now!
