Nye Samuel
Herr Katze
After nearly 6 months sterling service after a Naim service...the laser was deemed fine at that point.
Today without reason a thumping noise started from the speakers...but only from the CD input.
1. I disconnected and reconnected the cable from a 72 to the CDi...still the thumping noise appeared...not the tuner.
2. I switched the input from CD to tape thumping noise is still there.
3. I used the tuner lead and input...thumping noise is still there.
4. I changed the puck...for a little while it is quiet then the noise reappears.
5. I left it for a while...the noise has gone and I play a cd...then music stops...thumping noise begins...the noise will remain either with or without a CD.
Any idea as to what the problem is? It must be the player....laser? Or something else...Any advice would be appreciated....I will call Naim tomorrow.
