First you need to confirm whether is a CDM4 or CDM9 based CDI. Then you know what donor mech you need - you will be very unlikely to get the correct CDM4 or CDM9 mech (not sure of model in 4, 9 version is CDM9PRO), as the spin motors are very different on the top end models. Luckily the lasers are the same, and it is these that generally go. If it is a CDM9 based model, I used a CDM9/44 donor mech and transferred the laser across. Grandata sold remanufactured units a few years back, but I ended up going for an original and tested item from Les.
Is it definitely the laser? The pucks have a nasty habit of slipping as they get older, turning the rubbers sometimes helps, fitting a CD5 puck always works (to a CDM9, never played with a CDM4 based CDI). If it is CDM4 based then the standard Philips servo board used has some known issues with eletrolytics that can look like a laser issue too.
Below is a list of machines I started putting together when i didn't know whether my CDI was 4 or 9 based - it is completely unverified, and based on info on the 'net;
CDM 9 and 9 Pro equiped models;
ARCAM ALPHA 5 TDA1541 CDM9
MARANTZ CD23 CDM9
PHILIPS CD-692 Bitstream ? CDM9/63
PHILIPS CD-930/1 TDA1547 CDM9/44
PHILIPS CD-940 CDM9/44
PHILIPS CD-950 TDA1547 CDM9/44
PHILIPS CD-950/1 TDA1547 CDM9/44
CYRUS dAD7 AD1861 CDM9
Rotel RCD-980 CDM9
ROTEL RCD-990 PCM63P CDM9 pro
Marantz CD10 and CD11 CDM9 Pro
Meridian 602 - CDM4 Pro!
Philips CD630 CDM4/19
Meridian 206 Delta Sigma CDM4/19
aristona 1371 cdm4/11 (with Pro motor?!)
Philips cd371 cdm4/11 (with pro motor?!)
Philips CD-471 CDM4/11
marantz cd 50 60 CDM4/19
Philips CD 371 CDM4/11 or CDM2
Philips CD 373 CDM4/11 or CDM2
Philips CD 471 CDM4/11 or CDM2
Philips CD 472 CDM4/11 or CDM2
Philips CD 473 CDM4/11 or CDM2 (** 473/30 = cdm4/19, 473/00 = cdm2!)
Philips CD 650 CDM4/11 or CDM2
Philips CD 660 CDM4/11 or CDM2
Philips CD 670 CDM4/11 or CDM2
Philips CD 771 CDM4/11 or CDM2
Marantz CD65DX CDM4/11 or CDM2
arantz CD75DX CDM4/11 or CDM2
Philips Cd371 CDM2/29 (driect swap with cdm4/11?!)
Lastly, if he can't fix it, I'll buy it off him
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Good luck.
Richard
