Hi guys, new around these parts as found forum looking for CD5 info.
I have a CD5 here that been kicking about for years so i thought I'd make an effort to try and get it going again.
Managed to get a replacement pickup from Cricklewood Electronics, they have either the 12.4 mech or just the pickup. I ordered just the pickup and have installed it into the old mech.
So now it looks better as the disc will spin up initially (before it just used to kick the spindle motor..) but its not reading the TOC reliably.
After a number of manual play attempts it will and start playing a disc, the whole disc and seems to be very fast accessing different tracks with big jumps so tracking seems OK.
When you can get it to play a disc it does drop out and you hear distortion where the error correction flakes out at times.
Tried the puck stuff, its not that. I have a disc in there now where I've used a small piece of very thing double sided sticky tape on the hub part so the disc is not slipping.
All the supply rails appear to be OK, i think its just the pickup might not just be a good enough performance spec for the player.
Is there anything else i can try, i don't want to start buying more pickups in hope one might just work by chance..
Its really had to take measurements in operation due to the way its built, can't really get at anything to probe signals with a scope around the servo processor.
Also no service data about, I've just been trawling the web looking at sites with only ones with mods to do to glean any info.
Cheers
