Have you tried swapping the 321 cards between the two channels in the 72 and see if the problem follows the card swap?
Ahh a stop gap repair until your dream preamp is built....I understand now.
TBH I didn't really understand the benefits of local sense mod ...so left them all (I use 6, two in the hicap clone and 4 in the 72) in remote mode
I believe you will want local sense.
IIRC you only need remote sense for loads which vary in their current consumption as the remote sense will correct for the impedance in the supply wires as the output impedance of the ALWSR is so low. This can cause stability issues though, so probably better to use local sense, particularly if the load is relatively constant.
I can't quite see in the pictures, but don't take the signal gnds to your star gnd and then back to the signal gnd input on the MM cards. I did that with a pair of 323 cards and was very disappointed with the results, loss of sparked and clarity to the sound.
Best way is to connect the signal and the incoming signal gnd directly to the signal and gnd inputs on the MM cards. And as a separate connection from the card's PSU gnd to the star gnd.
I'll try to find the thread from many moons ago were I had the gnds incorrectly wired.
There you go, second post from @Jiiim
https://pinkfishmedia.net/forum/threads/some-more-phono-card-fiddlings.45649/
I didn't use a signal gnd star. R and L cables, signal and gnd direct to the card's signal and signal gnd. Power to the power connector and power gnd to power gnd star and then from there to the powers gnd on the card.Thanks for the tip. I put a provisional staple, made of two wires twisted together between the signal ground star and the card's gnd. A temporary connection made waiting to understand if it is better to link the card's earth also with the GND of the regulator. Did you do this last connection? In other words, do you linked only the incoming signal earth with the gnd inputs on the MM cards?
Does that make sense?
