Moving coil SUT's , UK suppliers .
Discussion in 'audio' started by early, Feb 3, 2022.
  1. early
    early pfm Member
    Hi all ,
    I'm not sure if this should be in DIY , but I'll try here first as it's busier .
    I want to build a SUT . I would normally just go to Sowter , but is there anyone else I should consider ? .
    Looking for 1:10 decent quality transformers that are stocked (or at least available) in the UK .
    Any suggestions ? .
  2. Mark Packer
    Mark Packer pfm Member
  3. early
    early pfm Member
    Thanks , don't really want to go the vintage Partridge route . I thought S&B stopped supplying to the public ? .
  4. Arkless Electronics
    Don't ignore head amps! ;)
  5. paulfromcamden
    paulfromcamden Baffled
  6. early
    early pfm Member
    I'm not, I've used them in the past. If I can't find a suitable transformer this is the route I will take.
    Although commercial offerings are thin on the ground, do you take on commissions?.
  7. early
    early pfm Member
    Seen that but can't find a 1:10 offering.
  8. paulfromcamden
  9. Arkless Electronics
    If you do enough searching on various forums you may well find stuff about head amps I've made. Sorry but too much else on ATM to take on a commission. I may have one available in a few months time though (long story...) but you'll probably be sorted by then.
