Guitar Beard
Hi I am selling my longridge Tri-plus mount cutter that is the perfect tool to cutting mounts for your photographs (saving yourself a load of cash). It has a straight cutter for cutting board to size and a 45 degree bevel cutter for the window aperture; it can cut single mounts and double mounts and will do multi-appertures.
It comes complete in its original box and i have only used it to cut approx a dozen mounts. It still has five of the original blades that came with it. There is a DVD manual and plenty of help online.
£90 delivered mainland UK, or £75 collected (and I can show you how it works over a cuppa), 5 mins from J24 of M5
I can email pictures of the work I have done with it
Jay
IMG_20190428_160013 by Jason Crammond, on Flickr
IMG_20190428_155926 by Jason Crammond, on Flickr
IMG_20190428_155018 by Jason Crammond, on Flickr
Jay
