Craig B
Re:trophile
Was that the 19mm mylar dome unit, @Radfordman?
Glad to hear that your Monitor 9 are sounding better, @matthew.
Just out of curiosity, do your tweeters look exactly like the example pictured below?
I own 2 pairs of MF MC2 speakers (they sit in the loft, must get round to selling them) and the tweeters are different on the early and later models.Thanks for sharing Simon.
l've only encountered the same glass fibre reinforced plastic face plates, same as on the MF ones.
One notable distinction between these MA tweeters and the MF MC-2 Mk1 and MC-4 Mk1 ones is that the latter were drilled through the centre pole piece with a rear wave damping chamber affixed behind the magnet.
MF's OEM tweeter model designation is quite a bit more telling than MA's...
25TAFC/G-MF
25mm, Tweeter, Aluminium, Ferro-fluid, Chamber, Grille, MF OEM
25TAFC/G-MF
Thanks for taking the time to do this, Simon (although your photo didn't appear).
Does your tweeter appear to be just like this one (perhaps with a different label)?
I would have expected an air core inductor there, not solid core.BTW, you can certainly tell that Robin Marshall had some influence over the design of the R852MD.
Some clean shots of the rather minimalist crossovers:
https://1drv.ms/u/s!AkeFH630HNzGgeRGfqPPf5ypclF7wA
https://1drv.ms/u/s!AkeFH630HNzGgeRHgUPtEkgEJEgjuw
Perhaps the designer choose a ferrite core to better reduce microphony which might modulate the inductance. It is in series with the bass/mid, so any inherent HF loss from an iron core should be irrelevant, welcome even.I would have expected an air core inductor there, not solid core.
Hi,Thanks for taking the time to reply, I have a pair of ma2 but its not them.. its a 70s80s bookshelf.. about the height of mordaunt short pageants but a bit deeper. I will get pics up as soon as I can. p.s the woofer surrounds are rubber with an inverted roll.(same as the ones on ma 4,5,6,18The only 3-way MA model that I recall as having a foam surround on the mid-range (and bass) driver was MA2 from the 1970s.
