Monitor Audio & Roksan Audio (+ News & Reviews) - At Musicraft (Derby)
Monitor Audio will be exhibiting at Sound & Vision The Bristol Show (26th to 28th February) 2016 - Suite 1008 on the 10th Floor and in Room 208 on the 2nd Floor
***** Musicraft - Clearance + Special Offers List http://www.pinkfishmedia.net/forum/showthread.php?t=98209 *****
***** https://www.facebook.com/MusicraftUK *****
***** Musicraft website - Special Offers list http://ww.musicraft.co.uk/special-offers/ *****
Rick @ Musicraft
The Norwegian launch of Monitor Audio's Platinum Series II of loudspeakers takes place at Spaceworld Soundgarden in Oslo this weekend. Platinum PL200 II and Platinum PL500 II will be on demonstration with a full Hegel Reference 30 Series System comprising of a HD30 DAC, P30 pre amplifier and H30 mono/stereo power amplifiers
Monitor Audio's new Platinum PL200 II loudspeakers - RRP £6299/pair
It’s unlikely you’ll discover a more persuasive speaker than the PL100 II in its price class, but compare the floor-standing PL200 II with its smaller sibling and immediately you’ll notice the effect of four drivers in a larger cabinet. Such is the quality of Platinum II’s engineering that the character of the sound remains powerfully consistent and expressive, but with the addition of a second 6.5” RDT®II driver, the PL200 II’s bass has more weight, while its dedicated 4” RDT II midrange driver brings further definition to vocals and strings. Through the PL200 II, subtle textures are more vividly described and every note rendered with greater authority. It’s a factor of scale. Platinum II’s class-leading accuracy is a given, you simply need to match it with the size of your room.
Monitor Audio's new Platinum PL500 II loudspeakers - RRP £15000/pair
Measured against its peers, there is no finer audio ambassador than the majestic PL500 II. Here you’ll discover the essence of Platinum II engineering: silken layers of the finest high frequency definition suspended on an explicit midrange, seamlessly underpinned by a deep, clean and responsive bass foundation. More than ever the sound has a physical authority, conveying the ‘live’ character of instruments, voices and atmospheres as if they had materialised three-dimensionally in the air around you. This is fidelity in the raw, magnificent in stature, seductive for its rhythmic subtlety and utterly captivating in the sheer magnitude of its dynamic impact. Our most sophisticated system of no fewer than four 8” RDT®II bass drivers, twin 4” RDT II midrange transducers and MPD tweeter will render the entire harmonic sweep of every work with pin sharp timing and accuracy. Your music and film sound alive, immersive and uncompromised.
Hegel HD30 Digital Control Center in Silver finish - RRP £3200
Hegel P30 Reference pre amplifier - RRP £5000
Hegel H30 Reference mono/stereo power amplifier - RRP £11000/each
Hegel P30 and H30 Reference pre/power amplifiers
***** Musicraft website - Special Offers list http://www.musicraft.co.uk/special-offers/ *****
Rick @ Musicraft
Monitor Audio's new Platinum Series II
If a pin drops, you’ll hear it. When the orchestra plays, it plays for you, so vividly and with such effortless scale you’ll believe you’re ten rows from the stage. This is the magic of high-end audio as experienced through the Platinum II speakers. Whether it’s a power chord exploding from a towering backline, the majesty of a choir soaring in union or the spell-binding gravity of a solo performance, you’ll sense the chemistry of music and musician more than ever before.
For over forty years our work as engineers and audio enthusiasts has been dedicated to this unveiling. With our most advanced driver, crossover and acoustic systems set within luxurious cabinets, we’ve tuned the virtues that have won Monitor Audio worldwide acclaim to a new intensity, allowing rarefied audio transparency to be revealed and enjoyed. Platinum II is our magnum opus, as inspirational and satisfying to us as we hope it will be to you.
Platinum II Range
• New RDT®II drivers with C-CAM® technology
• MPD (Micro Pleated Diaphragm) high frequency transducer, designed in-house for Platinum II
• HiVe®II High Velocity reflex port
• ARC® (Anti-Resonance Composite) mid-range driver housings and baffle components
• New patented 'DCF' (Dynamic Coupling Filter) mechanism for more natural sound
Platinum II Craftsmanship
The Platinum II cabinets are a statement of immaculate craftsmanship. Each is hand-built with the expert precision of the finest furniture makers, employing multiple laminations of veneer that are formed into a curved rigid shell. For the finish, natural wood veneers in Santos Rosewood or Natural Ebony are pair-matched, applied and hand-coated with 11 layers of clear gloss piano lacquer, then polished to reveal the glowing lustre in the grain. Platinum II models are also available in a penetrating piano black gloss lacquer, which will offer a luxurious contrast with room décor.
The front baffles are hand-upholstered with the very highest quality Inglestone leather supplied by Andrew Muirhead and used to distinguish many luxury British brands. Such is the level of care lavished on the Platinum II enclosures that each requires as many as 144 hours to complete.
Platinum II Technology
Platinum II offers you genuine audiophile performance with stunning design and materials specification. In the pursuit of ever lower distortion, no detail has been overlooked. Through meticulous FEA modelling we’ve optimised the operation of electrical, mechanical, magnetic and acoustic systems, introducing new discoveries to meet ambitious performance goals. The Platinum II range deploys an enhanced generation of RDT® bass and mid drivers, and for the first time in a Monitor Audio product, the MPD (Micro Pleated Diaphragm) high frequency transducer. Including improved crossover and speaker terminal designs together with proprietary ARC®, TLE, HiVe®II technologies, Platinum II builds on the award-winning advances of over forty years to create a high-end speaker range that is utterly faithful to the source.
Rick @ Musicraft
Website: www.musicraft.co.uk (THIS SITE IS BEING EVOLVED)
Please call 01332 346284, 07727 272443 or email [email protected]
Hours of business are Monday to Saturday 9am-8pm, Sunday 10.30am-4.30pm (please call before travelling)
***** Musicraft - Clearance + Special Offers List https://pinkfishmedia.net/forum/threads/musicraft-derby-demo-display-trade-ins-clearance-special-offers.235975/ *****
Rick @ Musicraft
Monitor Audio's new Platinum PL500 II loudspeakers at the 2016 Montreal Salon Audio Show
Monitor Audio's new Platinum PL500 loudspeakers
Rick @ Musicraft
Monitor Audio Gold C350 centre speaker
The Gold C350 centre speaker is a no-compromise centre channel solution for serious home theatre installations. Its three-way, four driver configuration mirrors that of the Gold 300, although the bass drivers are tuned to work in the Gold C350's sealed cabinet. Unsurprisingly the C350 is the perfect match for its floor-standing counterpart, producing frequencies from 40Hz to beyond 60 kHz. A neutral tonal balance and distortion-free sound give the C350 the ability to project crystal-clear dialogue and mid-range detail at any volume.
Monitor Audio. Design for sound.
Monitor Audio Gold C350 centre speaker with Gold 300 main loudspeakers
Gold C350 Technology -
• C-CAM® (Ceramic-Coated Aluminium/Magnesium) ribbon transducer design – providing extension to a class leading 60KHz
• Single bolt through driver fixings for improved bracing, rigidity and driver/baffle de-coupling
• New C-CAM RST® (Rigid Surface Technology) bass/mid-range driver
• Die-cast alloy terminal panel arrangement with high quality bi-wire terminals and high end spade type link cables
• Pureflow® silver internal cabling
• Selected premium quality wood veneer or high gloss lacquer finishes
• Rigid 20mm MDF construction throughout, employing radial and cross-bracing techniques for high rigidity resulting in low cabinet colouration
• Invisible magnetic grille fixings provide a sleek visual effect.
Gold C350 Specification -
• System Format 3-Way
• Frequency Response 40 Hz - 60 kHz
• Sensitivity (1W@1M) 90 dB
• Nominal Impedance (ohms) 8
• Maximum S.P.L (dBA) 113.8
• Power Handling - R.M.S. (W) 200
• Recommended Amplifier Requirements (W) 100 - 200
• Bass Alignment Sealed Cabinet
• Crossover FrequencyL.F - M.F: 800 Hz, M.F - H.F: 2.3 kHz
• Drive Unit Complement 2 x 61/2" RST® bass/mid-range driver, 1 x 4" RST mid-range driver, 1 x C-CAM® H.F ribbon transducer
• Cabinet Dimensions (HxWxD) 254 x 581 x 333 mm, (10 x 227/8 x 131/8 inch)
• Complete Dimensions Inc Terminals (HxWxD) 254 x 581 x 360 mm, (10 x 227/8 x 143/16 inch)
• Weight (each) 19.6Kg (43lb 2oz)
Monitor Audio Gold C350 RRP £999 (Dark Walnut Real Wood Veneer, High Gloss White Lacquer and Piano Black Lacquer. RRP £1199 (Piano Ebony)
Rick @ Musicraft
Hi-Fi Choice reviews Monitor Audio's Silver 8 loudspeakers
http://www.hifichoice.co.uk/news/article/monitor-audio-silver-8--pound;1250/20489
The Silver 8 has a new three-way design, optimised to deliver superb midrange focus and precision as well as extended bass. Effortless room-filling dynamics, even in larger spaces.
http://www.stereophile.com/content/monitor-audio-silver-8-loudspeaker
Stereophile review Monitor Audio's Silver 8 speakers
Monitor Audio Silver 8 loudspeakers - AV Tech media Awards 2015/2015 winner for Best Floorstanding Speaker
Silver 8: "Bass is well articulated, midband is crisp yet smooth and treble is beautifully detailed. The Silver 8 delivers a rewarding performance with everything you throw at it, and is sublime at the price."
Monitor Audio Silver 8 Technology -
• Improved C-CAM® (Ceramic-Coated Aluminium/Magnesium) gold dome tweeter design with damped rear chamber and innovative dome venting technique for improved clarity and wider operating bandwidth.
• Specially developed 4” mid-range driver with ‘under-hung’ voice coil and motor system. The voice coil remains in the magnetic gap ensuring very low distortion - better damping and improved mid-range clarity.
• Dual 6” bass drivers featuring concave ‘dished’ C-CAM cone profile.
• RST® (Rigid Surface Technology) cone profile, for improved diaphragm rigidity and reduced distortion.
• Three-way configuration allows drivers to be optimised to deliver better overall performance.
• Improved cast polymer bass chassis design for better rigidity and reduced reflections.
• HiVe®II port technology delivers smoother airflow for better transient response and tighter bass.
• Single bolt through driver systems for increased overall bracing, rigidity and driver/baffle de-coupling.
• Pureflow® Silver plated OFC copper internal cabling.
• High quality crossovers with premium grade polypropylene film capacitors.
• Available in selected premium quality wood veneers or high gloss finishes.
• Rigid 20mm MDF construction throughout, employing radial and cross-bracing techniques for high rigidity and low cabinet colouration.
• Invisible magnetic grille fixing provides clean visual styling when the grille is off.
• Terminal panel at floor level for easy cable connection.
Monitor Audio Silver 8 RRP - £1250/pair (Black Oak Real Wood Veneer, Natural Oak Real Wood Veneer, Rosenut Real Wood Veneer, Walnut Real Wood Veneer), £1375/pair (High Gloss Black Lacquer, High Gloss White Lacquer)
Rick @ Musicraft
The Absolute Sound reviews Monitor Audio's Gold 300 loudspeakers
http://www.theabsolutesound.com/articles/monitor-audio-gold-300-loudspeaker/
Monitor Audio Gold 300 loudspeakers in Piano Ebony finish
Monitor Audio Ltd is a British owned and managed global specialist in hi-fi loudspeaker design. For over 40 years we've been incorporating stereo and surround sound systems and a range of sonically matched architectural speakers for ultra discreet high quality sound around the home and outside.
Whatever your taste and budget you'll discover a Monitor Audio speaker that answers your desire for great sound. Since hi-fi was in its infancy we've dedicated all our technical expertise, innovation and craftsmanship to the creation of world-class loudspeakers, which communicate the essence of our brand and reward the people who buy them. We want you to share and enjoy the blend of style, quality, performance and sophistication that makes Monitor Audio unique.
http://ca2.monitoraudiocdn.com/down...old_300_Reprint-LOW.pdf?mtime=20150821134145#
Hi-Fi News reviews Monitor Audio's Gold 300 loudspeakers
http://canadahifi.com/monitor-audio-gold-300-loudspeakers-review/
Canada Hi-Fi reviews Monitor Audio's Gold 300 loudspeakers
Standing at over a metre tall the Gold 300 is a majestic three-way floor-standing loudspeaker comprising twin 6.5" bass drivers, a single 4" mid-range driver and a high frequency ribbon transducer. With such an impressive complement of drivers, the Gold 300 has the power delivery and scale required to fill the largest rooms with jaw-dropping dynamics as well as the finest musical detail. Extending from below 30Hz to over 60kHz, its frequency range is among the widest available from any speaker, regardless of price.
• HiVe®II port technology for better transient response and tighter bass
Monitor Audio's Gold 300 loudspeakers RRP £3000/pair (Dark Walnut Real Wood Veneer, High Gloss White Lacquer and Piano Black Lacquer), £3600/pair (Piano Ebony)
Rick @ Musicraft
Monitor Audio at the ISE show, RAI Amsterdam, Netherlands (7-10 February 2017)
Rick @ Musicraft
Monitor audio will be exhibiting at Sound & Vision The Bristol Show (24th to 26th February) 2017 in Suite 1008 on the 10th Floor and in Room 208 on the 2nd Floor
Rick @ Musicraft
Monitor Audio at Sound & Vision The Bristol Show (24th to 26th February) 2017
Rick @ Musicraft
Monitor Audio's Silver 8 loudspeakers has received an "Exzellent" award from Stereo Magazine in Germany
http://ca2.monitoraudiocdn.com/downloads/reviews/Silver_8_Stereo.pdf?mtime=20170316093922
"The Silver 8 is a successful, dynamic all-rounder with distinct audiophile qualities, which will make a good impression in many living rooms and configurations. A mix of visual elegance, very good material and built quality, a non “brutal” straight-forwardness and an attractive price, which will ensure its success.”
Rick @ Musicraft
Monitor Audio will be exhibiting at the 2017 (May 18 - 21) High End Munich Show - Room/booth Halle 4 R06/T07
Rick @ Musicraft
Monitor Audio at the 2017 High End Munich Show
Rick @ Musicraft
Monitor Audio and Roksan with the new Silver 6G Series of loudspeakers at the 2017 High End Munich Show
Rick @ Musicraft
Monitor Audio's new Silver 6G Series of loudspeakers - Step up in sound video
https://www.youtube.com/watch?v=P9FiY0xd7kU
Rick @ Musicraft
Monitor Audio's new Silver 200 loudspeakers
The Silver 200’s sleek appearance makes it a truly compact and attractive floorstander, blending audiophile performance with lifestyle proportions. A pair of Monitor Audio’s unique 5¼-inch C-CAM bass drivers share the duties of delivering bass and mid/bass. Configured as a two-and-a-half way system both electrically and acoustically, you will be amazed at the magical sound quality that this slimline can produce in your home.
Monitor Audio Silver 200 RRP Black Oak, Walnut, Rosenut, Natural Oak and Satin White £1000/pair, High Gloss Black £1100/pair
The two bass drivers operate in separate acoustic chambers within the enclosure to provide differential tuning and are divided optimally with crossovers to ensure both bass drivers contribute to the lower frequencies. This ensures only the mid-range crosses over with the tweeter and results in a consistent and precise image, on and off axis. This configuration delivers performance approaching a three-way design whilst ensuring higher efficiency and extended low frequency, yet in a smaller cabinet.
The drive units are constructed with massive magnetic systems capable of deep bass extension. The low-frequency response has been engineered to provide smooth roll-off without exhibiting any of the usual ‘overhang’, meaning that the Silver 200 can be sited close to a wall and provide the ideal blend of domesticity and blazing performance. Diminutive for a floorstander, this model is no slouch. The Silver 200 is a serious audiophile speaker with amazing drive and incredible musicality. The engineering challenge was to create a smaller box with bigger sound; with the Silver 200, Monitor Audio achieves that goal so that you can enjoy your music and films with convincing realism.
Monitor Audio Silver 200 Technology -
• Two-and-a-half-way, three-driver configuration
• Differentially-tuned acoustic system means high efficiency with powerful low-frequency extension
• New 25 mm C-CAM, (Ceramic-Coated Aluminium/Magnesium) tweeter featuring vented Neo magnet system optimised for lower distortion and cleaner sounding highs
• New 5¼-inch bass and 5¼-inch bass/mid drivers with ‘dished’ C-CAM cone profile for better damping and improved mid-range clarity
• RST Cone profile for improved diaphragm rigidity and lower distortion
• Unique-build ring/voice coil-cone coupling mechanism (DCF) optimised to reduce high-frequency cone break-up and increasing the critical voice coil circumferential rigidity
• Cast polymer driver chassis design for improved rigidity and damping characteristics
• HiVe II port technology means better transient response and tighter bass, due to smoother airflow
• Pureflow silver-plated OFC copper internal cabling for the highest quality transfer through the signal chain
• High-quality crossovers utilising premium grade, bespoke polypropylene film capacitors, air-core and low-loss laminated steel-core inductors results in maximum signal transfer
• Rigid 20 mm MDF construction utilising scientifically optimised cabinet bracing
• Single bolt-through driver technology providing increased bracing strength, rigidity and driver/baffle de-coupling
• Ultra low-profile grilles featuring invisible magnetic grille fixings for clean visual styling when fitted
• High-quality crossovers with premium-grade polypropylene film capacitors throughout
• Bespoke, high quality bi-wire terminals
• Terminal panel located at floor level for easy termination and neat cable access
• Out-rigger feet (spiked, or rubber for hard flooring) provide attractive appearance while taking up less floor space
• Selected, premium-quality wood veneers, high gloss lacquer and contemporary Satin White finishes.
Monitor Audio. Making Audio Human.
Rick @ Musicraft
Monitor Audio's new Silver 200 loudspeakers win the 2017 What Hi-Fi Best Buy award for Best Floorstanders in the £800 - £1200 category, with What Hi-Fi? adding 'Most important, though, is the richness and clarity throughout'.
Monitor Audio's new Silver 200 loudspeakers are at Musicraft (Derby)
Rick @ Musicraft
Monitor Audio's new Silver 100 loudspeakers.
Monitor Audio's new Silver 100 loudspeakers are at Musicraft (Derby)
The Silver 100 is a serious audiophile speaker capable of producing remarkable resolution, from the most intricate musical scores to the loudest rock concert, with superlative ease.
Monitor Audio Silver 100 RRP Black Oak, Walnut, Rosenut, Natural Oak and Satin White £650/pair, High Gloss Black £715/pair
High output and effortless dynamics make the Silver 100 an ideal choice for medium to large rooms in two-channel stereo or multi-channel application.
Silver 100 features a massively powerful 8-inch C-CAM RST bass/mid driver rigidly fixed into a relatively compact two-way cabinet in a configuration that while relatively traditional by modern standards has a lot to offer. There is no real substitute for big drivers and their relative ease of moving air efficiently. Thus, they can deliver incredible dynamic headroom and bass extension, a feature normally reserved for floorstanding speakers.
A two-way, ported design, the Silver 100 relies on a new, 25 mm C-CAM tweeter made from the brand’s proprietary Ceramic-Coated Aluminium/Magnesium, and featuring a vented Neo magnet system, to create the cleanest possible highs. The HF unit is coupled with a specially-designed 8-inch bass/mid driver featuring a concave ‘dished’ C-CAM cone profile for incredible levels of damping and improved mid-range clarity. You’ll certainly hear the difference with Silver.
Monitor Audio Silver 100 loudspeakers Technology -
• Unique RST Cone profile for best diaphragm rigidity and lowest distortion
• Proprietary-build ring/voice coil-cone coupling mechanism (DCF) optimised to reduce high-frequency cone break-up and increase the critical voice coil circumferential rigidity
• Cast-polymer driver chassis design for improved rigidity and damping characteristics
• HiVe II port technology ensures linear transient response and tighter bass, due to smoother airflow
• Pureflow silver-plated OFC copper internal cabling means the highest-quality transfer through the signal chain
• High-quality crossovers with premium grade, bespoke polypropylene film capacitors, air-core and low-loss laminated steel-core inductors for maximum signal transfer
Rick @ Musicraft
