philiphifi
hi
Does anyone know how to modify one lineout of my valve pre amp to a headphone out?
Thank you
Philip
Thank you
Philip
Just looked up the shematic - an M7 hasn’t a hope of driving headphones directly. Build an add-on amplifier for that task
thanks for your input. What would be needed to turn one output to drive a headphone? Easiest option please
The basic problem is, the output 'drive' available from the M7 is derisory; it is direct, from the high-impedance output port (the anode, c.>8Kohm effective) of a teeny-tiny signal triode: via an utterly-feeble value coupling-cap. It just does not, cannot, does not posess the spare AC current to drive even 300ohm headphones - you'd get a bass roll-off below c 5Khz (so fizz and noise only) and the current draw would utterly collapse the preamp's performance: the M7 is a preamp only suitable for loads above c 100,000ohms ( and even that has caveats...)
Sorry!
