Following on from my attempts to get the Shure V15 111 singing I now have a 774 tonearm which by all accounts should work beautifully with the V15. Setting the arm is proving a bit puzzling! With the correct S2P distance I can't obtain the 229mm effective length because the wires that exit the wand will be squashed by the clamp ( you need to be familiar with this arm to fully understand what I mean). So I seem to be stuck with approximately 234 effective length and to complicate things further the cartridge offset angle is pretty much set at 21 degrees ( I have checked this). So how on earth do I achieve a reasonable alignment? Hopefully I can get some useful info/insights from 774 users.
