D-C
Hi all,
I had an accident with the above (long story) and I'm no longer getting sound through the balanced headphones. I'm trying to determine if its the amp or the headphones that are knackered.
Likely the amp but it's not something I can check as I've only got the 1 pair of MF200b headphones.
I've had a look inside the amp and there's nothing obviously wrong with the PCB, everything looks in its place, nothing bent or broken, all connections look fine.
The unbalanced output works perfectly well with other headphones.
Any idea on how I can troubleshoot this issue?
https://i.imgur.com/BFNpthz.jpg
https://i.imgur.com/5fOu86o.jpg
https://i.imgur.com/4Hc2jhQ.jpg
Cheers,
DC
Cheers,
DC
