trumpetman
My Melco has been visible on my main computer and laptop on my home network for ages with no problems.
Recent Microsoft updates I suspect have rendered the Melco now not visible on the network. Everything else is – shares printers etc
I have looked extensively on the internet for solutions e.g enabled and disabled SWBv1, checked network discovery, checked and double checked Advanced network sharing settings
This Melco suggestion is weird
https://www.melco-audio.com/support/faq/
Find "Windows Credentials" on ◎(Cortana) task bar => click"Add a Windows credential"
=>Address:\\(friendly name)
User name: nobody
Password: nobody
I have done this – BUT the password saved has 8 digits not 6 no matter how many times I enter it, delete and re-enter – this might be the problem but I don’t know how to fix it
Has anyone else had such problems? Can anyone give some extra advice what to check, click, declick or swear at?
Nigel
- Home network is all win10 machines, three desktops and one wireless laptop
- Melco is connected to network using Tplink powerline adapters for 5 years +
- Melco and internet tuner, Magnum Dynalab MD801, function as normal
- Being visible on network means if I need to tweak a tag or artwork then it can be done quite easily
User name: nobody
Password: nobody
Nigel
